Configures the grace period sent out in Grace-LSAs and used by a restarting router.
| seconds | Grace period, in seconds. The default value is 120 seconds. Range is 1 to 1800 seconds. |
The default is 120 seconds.
This command configures the grace period sent out to helper neighbor routers and used by the restarting router. The value of the grace period must be greater that the dead interval, and less than the LSA refresh time.
The following command configures a router to send LSAs with a 240 second grace period during graceful OSPF restarts:
configure ospf restart grace-period 240
This command was first available in ExtremeXOS 11.3.
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
